PCIe Bifurcation Motherboards?
True, but there doesn't appear to be a version of it with the slots coming out the other direction.
rokabeka
network packet manipulator
Jul 9, 2016
234
251
thanks a lot!
I have received lot of help in pm's.
finally I will get mine through Aibohphobia.
LukeD
Case Designer
Jun 29, 2016
481
1,254
Asrock X370 ITX/ac support PCIe bifurcation and with a little bit of tweaking you can also get SLI to run :)
No artefacts, no funny business :)
Mind you this was no apples to apples comparison as I only have 7700k benchmarks to compare against... and I can't be bothered to set this up on an ATX X370 board ... but the performance diff is consistent.
Biowarejak
Maker of Awesome | User 1615
Mar 6, 2017
1,731
2,220
Are you planning to either detail the tweak or release it?
the_kingdom
Hey guys, sorry to slightly highjack the thread here, although may be nice to revive it, as this is an interesting area for SFF guys.
So I did a build:
CASE: Corsair Crystal 460x
MOBO: mITX motherboard(GA Z170N Gaming 5).
GPU: GA GTX 1070 FTW
I started getting into smaller scale mining and realized a ran into a problem when I thought I could SLI another GPU on this mobo.. clearly I was wrong.
Is there a way to run a PCIe Bifurication//Splitter//Riser to allow connecting another EVGA GTX 1070 FTW?
Motherboard Native Graphics interface is PCIe 3.0 x16
Help would be greatly appreciated
meganie
Yes, I believe it does need a firmware update, the second latest 2.30: http://www.asrock.com/mb/Intel/Z87E-ITX/?cat=Download&os=BIOS
I do have the customized 2.50 available to enable Bifurcation if you ever get around to it.
CPU BIOS compatibility list: http://www.asrock.com/mb/Intel/Z87E-ITX/?cat=CPU
Hello, could you send me the BIOS if you still have it? I would like to give my old board a second life with a bifurcation adapter and some NVMe storage. Thank you very much!
