Hey guys, I've tried searching on the site but couldn't find an answer.
What is the panel mount that is compatible with the DELL Alienware 330W AC Adapter Y90RR XM3C3 ADP-330AB DA330PM111 ?
I assume you mean the inlet to the case? I'm using the larger barrel adapter that comes with the HDPlex 250 if that helps. It is listed on their website as 7.4x5.0mm with Center PIN(Ground) DC Input PCB
