Image Credit – Palit
Those waiting for a major boost to the ITX class GPU market may finally be getting it. Leaked product SKUs from Marvel.ru show two Palit STORMX models. Both feature 8GB of GDDR6 on a 128bit bus, and the 4060Ti GPU. Performance estimates for the 4060Ti put it roughly in the range of the RTX 3070 or RTX 2080Ti. This is while using only 160 watts of power.
Keep in mind that all of the specs are rumors. However, if they are true, the raw processing power of the 4060Ti should be a solid step up from the RTX 3060Ti, but the graphics memory bandwidth a major step down. The 3060Ti had a 256 bit bus. Additionally, rumors indicate that the 4060Ti may only support up to PCIe Gen4 x 8 instead of x16.
Check out the Videocardz article by...
Continue reading...
Reactions: Phuncz and rfarmer
7,411
Yay! Small! Although I expect this to be very... aurally noticeable.. under load
