Hi guys,
A few weeks ago I set out on the task of making myself a HTPC, but I wanted something special, so I shoved a whole computer inside of an original xbox case.
Finished Product:
Specs (Already had some components from previous build):
PCPartPicker part list: https://uk.pcpartpicker.com/list/K4Z7bj
CPU: Intel - Core i5-7600 3.5GHz Quad-Core Processor (£201.00 @ Amazon UK)
CPU Cooler: Silverstone - AR06 40.2 CFM CPU Cooler (Purchased For £0.00)
Motherboard: ASRock - H270M-ITX/ac Mini ITX LGA1151 Motherboard (£108.16 @ BT Shop)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (£112.98 @ Ebuyer)
Storage: Western Digital - Green 120GB M.2-2280 Solid State Drive (£52.31 @ CCL Computers)
Storage: Seagate - Momentus SpinPoint 2TB 2.5" 5400RPM Internal Hard Drive (Purchased For £0.00)
Storage: Seagate - Archive 8TB 3.5" 5900RPM Internal Hard Drive (Purchased For £0.00)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Low Profile Video Card (£138.16 @ CCL Computers)
Power Supply: SeaSonic - 300W 80+ Gold Certified Fully-Modular Flex ATX Power Supply (£60.00)
Other: NOCTUA NF-A6x25 PWM (£11.90)
Other: Original Xbox (£15.00)
Total: £699.51
Some Comments:
Graphics card never reaches 65c~ under load
Processor almost never reaches 70c~ under load
I was really worried the small FlexATX power supply would sound like a jet as its basically a server power supply, but the fan is completely silent, even under load. I had to check that the fan was working as I was getting worried but all is good!
Fans are audible in a quiet room but any noise will drown them out (like from a TV).
Side fan is set to silent, I don't think I needed to use it with the middle cut out and meshed.
Runs Windows 10 Enterprise with a custom shell that boots into Kodi for TV, Movies, Music, etc.
Has the option to launch BigBox which is an awesome emulation frontend that I highly recommend. It can run anything up to and including Wii U games (Although that emulator is still in development!).
Build Log Album (Has lots of comments on how I made it):
If you guys have any questions feel free to ask
Finished Product:
Total: £699.51
Some Comments:
