Concept OptiCool cases: uSFF cases with great compatibility
SFF Watercooled
398
172
Orion
Goal
: Sub 8.5L 240mm AIO case with slim fans
Dimensions: 301mm * 128mm * 220mm
Volume: 8.48L
2 slot mode
GPU:
296mm * 140mm * 40mm
CPU cooler height: 67mm
2.5 slot mode
GPU:
296mm * 140mm * 50mm
CPU cooler height: 57mm
3 slot mode
GPU:
296mm * 140mm * 60mm
CPU cooler height: 47mm
Radiator + fans max total thickness: 46mm
Radiator max width: 124mm
Material: 1mm - 1.2mm steel
____________________________________
Orion X
Goal:
Sub 10L 240mm AIO case with more compatibility and 25mm thick fans
Dimensions: 339mm * 128mm * 230mm
Volume: 9.98L
2 slot mode
GPU:
335mm * 140mm * 40mm
2.5 slot mode
GPU:
323mm * 140mm * 50mm
3 slot mode
GPU:
323mm * 140mm * 60mm
Radiator + fans max total thickness: 56mm
Extra notes
Flipped orientation makes smaller dimensions possible
The layout will be the same as the FormD T1 for easier cable management and smaller volume
medevil
If you could put a power button and a type c (or usb) on the front would be perfect.
Alloy Craft
Modultra
Oct 25, 2019
140
603
So essentially you have done next to nothing and your not sure you want to continue? How are you getting the 1L smaller number? Do you actually have a cad model?
SFF Watercooled
398
172
Dimensions. Multiply them out. The T1 is larger in every dimension, so it's 1L larger
Marwan
125
125
from the measurements, am guessing the layout is similar to some other cases where the Rad and fans are fitted either below or above the motherboard.
quick notes for you if would like to continue:
Itx mb is not 100% 170x170 mm its actually 175x172 because of the i/o shield and the spacing for it. so you will need few millimeters vertically for the case.
As for the width of the case it depends on your material choice. and it affects your choice of both gpu and cpu cooler.
1mm for aluminum is rather thin you may opt for steel at this thickness.
good luck.
SFF Watercooled
398
172
good luck.
That's exactly why I'm using a flipped orientation. Hope that explains everything. (FormD T1 layout)
Also, the 172mm is considered in the dimensions, it'll essentially have the PSU right next to the mobo.
good luck.
Ok, will be changing from alu to steel
