Log Open Build with Crow's Bluff Design Elevation
HWI
101
84
I recently moved a build into the Crow's Bluff Design Elevation "case". It is exceedingly easy to build with and I haven't seen or heard much on it so I thought I would share it.
14600K
Scythe Mugen 6 DBE
Gigabyte Gaming OC RX 9070 XT
Asus ROG Strix B660-I
Corsair Dominator 32GB DDR5 6400 CL32
Cooler Master V SFX Gold 850W ATX 3.0
The fan on the PSU is the loudest component under load, might do a NF-A9x14 fan swap like I saw here.
HWI
101
84
Update on the PSU fan swap. I swapped in a Scythe Kaze Flex 92mm slim fan I had on hand and it completely solved the noise issues. I don't understand why Cooler Master ruined an otherwise perfectly fine PSU with such a cheap fan.
