Hello,
I've noticed some fan/vibration noise from top fans. I don't know if it is due to the simple fan holder that came with the case(top fans are currently not screwed in). Does anyone know the specs for top 120mm fan screws. I found UNC 6-32 30mm? or go with 35mm instead?
EDIT: Hmmm, i see some screws on the "fan-holder-thingy" that came with the case and i'm not sure if i can use them insted?
