Discussion 15mm fan screws
Dawelio
Awesomeness
530
445
Hello everyone,
So I have a question for you all, does anyone in here knows which kind of screws that is required for Noctua NF-A12x15 PWM Chromax fan to be installed on an AIO? More specifically an NZXT Kraken Z series of AIO. Considering it's only 15mm thick and hence not normal size, the included screws with the AIO is obviously too long.
Thanks,
Dawelio
dondan
DAN Cases
1,966
8,288
Use the included 4 screws of the AM4 socket plastiv parts of the motherboard. These screws are UNC 6-32 with the correct length.
Dawelio
Awesomeness
530
445
Thanks for the quick reply! :)
Do you mean the silver screws that hold the 2 black plastic brackets on the socket?...
Also I need 8 screws in total, so unfortunately only 4 is a bit short.
