So, I'm new to the SFF world, and my Dan A4 v2 has just arrived, and my question is...
Can anyone suggest whether a Turbo or Strix is a better move, for the Dan A4 v2?
I'm primarily concerned about noise, I think.
I say this because I believe I could maybe address thermal issues with either:
Whereas, if I buy the Turbo, and it's noisy, I'm stuck with it. No returns, etc.
So is the Turbo or Strix better suited, in your experience / mind, to the Dan v2?
It may help if I add that the build will include a 8700 with the Noctua NH-L9i as the CPU cooler.
If you want to think of this as a "blower vs open-air cooler" question, that's fine... just that my choices are specifically between the Strix and Turbo, both from Asus.
And more specifically still, if you must know, my choice is between either the 1060 or 1080 Strix... or the 1060 or 1070 Turbo.
I'm really grateful in advance for any advice / guidance!
- ducting / compartments,
- or adding another case fan or two,
- or by moving into a different SFF case entirely!
