Hello all,
When looking at PCPartPicker I wanted to confirm compatibility with the case and GPU, and it showed as compatible.
It kinda is, with some modding, and since the Node 202 is a decently popular SFF case, I decided to share my findings.
It really isn't possible to keep the bracket flange as bending it would cause interference with the case or card, depending on the direction, hence it must be cut off. As there is a top flange and is screwed in on both sides of the top as well as the bottom center, there is still a decent amount of structural rigidity.
As for GPU length, the Zotac AMP 2080 really is the longest you would want at 308 mm, without heavy modification of the case or GPU. I have not yet tested with the shroud removed and full-sized fans, though it may be something I attempt in the future.
All in all, I'm decently happy with how everything is running. CPU and GPU generally keep in the high 50's °C.
The only other problem is the USB 3.0 cables that go to the front. In order to prevent them hitting the fan they need to be tied down to the front grill. I'll get photos of that later.
Additionally, if you're going to keep the GPU brace, be sure that you don't put too much pressure on the GPU or it may cause fan interference.
