Hi
At first, sorry for my bad english
Coming from a 2080S Strix with a 3700X I've upgraded to a MSI Ventus 3090 OC and a Ryzen 5950x.
I was planning to get a 5800X or 5900X but the 5950X was the only available CPU in store that day and I knew this is going to be difficult to air-cool and well, it is
this is my setup:
Ncase M1 6.1
5950X
2x 16GB@3800Mhz
Ventus 3090 OC
Strix 570-I
Noctua C14S with Noctua A12x25 PWM below exhausting through the cooler and towards the panel
Corsair 750W in ITX position pulling air from the sidepanel and exhausting on top (i prefer it pulling as cold air as possible independent from the rest of the system)
2x Noctua A12x15 as exhaust on the Fan/Radiator bracket
1x Noctua A9x25 in the back which I'm currently not using as it creates noisy turbulence even at low RPM between the AF12x15 mounted next to it.
To my suprise, cooling the CPU under full load is a non issue with a C14S. In fact it runs cooler than my 3700X which I still can't believe.
I've tried many different fan setups in the past and I did get the lowest temperatures overall when I ran all the Noctua fans as exhaust, the only fans pulling air in are the ones from the GPU at the bottom.
This configuration did work great, although the CPU did get a little warmer having to deal with the heat coming from the 2080S under load.
With the Ventus 3090 it's a complete different story, that card generates so much more heat which is mostly being pulled out through the CPU cooler and the two A12x15 and it heats up the CPU reaching 70°C+ doing nearly nothing.
So I came up with a few ideas:
1)
Deshroud the Ventus 3090 (I got it for this reason) and put two A12x25 below. But in the prefered intake position all the heat would still go through the fans and the cpu cooler on top of it. I might lower the noise but the problem won't be solved.
2)
Deshroud the Ventus and try two A12x25 in exhaust and switching the all the other fans on top to intake. I know this is regarded as the best solution for deshrouded GPUs but some guy did this with a Ventus 3080 and the results weren't that great, infact the GPU temperatures were lower with intake position.
3)
Deshroud the GPU sometime later and mount as many Noctua A9x14s between the sidepanels and the GPU pulling and exhausting all or most of the hot air out of the case before it reaches the area of the CPU on top. I've noticed I could fit at least 3x of them between the sidepanels and the GPU. Two on the left side below the NF12x15 and one would fit below the PSU on the right side. Mounting will be an issue but should be possible somehow.
Please check the pictures
I made them using the A9x25 which of course is too wide but there is definitely enough space for 14mm width fans, especially if I mount the sidebracket with the two A12x15 in the higher position.
What do you guys thing could work best?
Thanks a lot for your input.
this is my setup:
Ncase M1 6.1
5950X
2x 16GB@3800Mhz
Ventus 3090 OC
Strix 570-I
1)
2)
3)
