Hello SFF Forum, and all ye who inhabit it. I've been watching you from the shadows of non-membership for some time now, having heard from you not only from the likes of @TekEverything, but also your wonderful subreddit, r/sffpc. You guys got some quality people among your ranks.
I'm currently enjoying a very nice build with a Ryzen 1600 clocked at a comfy 3.85 gHz and an EVGA superclocked GTX 1070 with a monitor at 1440p, and I really enjoy the power and functionality of the whole machine, as well as the sleek design of my NZXT case. I just have one little problem.
The case is 40 liters in volume.
Now before you guys break out your pitchforks and torches, in my defense, it was my first build I finished about a year ago, and someone told me that I should stick to the ATX form factor. I simply didn't know better.
That is, until a particular post by a member by the name of @ZMan caught my eye. To paraphrase his perspective, he felt that putting about 3 liters of hardware inside a case ten times the volume was, for lack of a better word, silly. He proposed his "Gallon" 3D printed case, and my eyes were forever opened.
Since then, I've scoured the weirdly sparse and abundant landscape that is mini-ITX cases, searching for one that matched exactly what I've been looking for.
I've seen cases that look like they wandered into the 90's and got lost. I've seen gorgeous hunks of aluminum with price tags that make my graphics card blush. I've also witnessed my fair share of those in between, who seem to have managed the worst of both worlds.
My search has not ended.
My hunger persists.
I call upon your numbers, o people who know more than me. I request your aid in this subject that you must know more about than I do. Help me, and I shall be eternally grateful.
These are the specifications that I'm looking for:
Size: Ideally, small enough to fit inside my backpack. I'm currently a student, and I travel from my University to home fairly often, a trek that is over 700 miles. I'd like to take my glorious PC with me on my journey.
Material: I want it to be durable, but it doesn't need to be hyper-quality super-matte-brushed aircraft-grade titanium. I'm skeptical of all plastic cases, but I'm open to someone changing my mind.
Appearance: Jeez guys, I don't care about how many rainbows the case can vomit while I'm using the computer inside it, the point of the computer is that I'm looking at the images it produces on screen, not off. If it's simple, not attention grabbing, or looks like a office workstation, I'm down. If it has more self advertisement than an unemployed business major, no thanks.
Cost: I really don't want to spend more than $150 on a painted hunk of metal and/or plastic that doesn't do anything but hold things in place. *cries out to the sky* Dear God, is that too much to ask?!
CPU: I'd like to be able to fit a Ryzen 2600X inside, with enough cooling that it doesn't sound like a wind turbine. Because of this, I've looked to watercooling to keep the temperatures and noise low. Space enough for a 120mm (or maybe even a 90mm?) radiator should be enough. That being said, it has a TDP of 95W, so a good aircooler could be enough
GPU: Enough space for a 20-series Nvidia GPU. From what I've gathered, they run hotter than Emma Watson on coals, so I'm not sure how short they'll manage to make em. For now, the founder's edition length of 267mm should be a good maximum. If that's out of the question, I don't have any interest in going above 1440p @144Hz.
Side note: if there's some case out there that's got just enough space for a 240mm cooler for both CPU & GPU, and doesn't cost $500 (looking at you, Circle Pro), I'm also open to that idea.
PSU: ATX, SFX, or Flex-ATX. I feel like a pico/nanoPSU + a power brick at this level of power are either more expensive than they're worth, or not enough power. Again, open to someone changing my mind.
Drives: Man can survive on M.2 slots alone, but support for a 2.5" drive could be nice.
Those are my wishes, o genies of the internet. Aid me, denizens of the infinite knowledge, and I will be sure to return the favor. If you've read this far, I hope I've at least entertained you fellas a bit.
Thank you for your help, my friends. May your volume be low and your power be high.
My hunger persists.
