Hi All,
We had promised a PC to our son after his good results at school. He wanted a white themed PC with LOTS of lights...
Since I think that I do not have yet the option to share links here goes the HW used :
Case : Coolermaster NR200P
Mobo : Asrock B550 Phantom Gaming ITX-AX
CPU : Ryzen 5600X
SSD : Lexar NM790 2TB
RAM : Corsair Vengeance RGP Pro SL 32GB (CMH32GX4M2E3200C16W)
Cooler : Thermalright Assassing King 120 SE ARGB (fits perfectly)
GPU : Gigabyte Geforce RTX 3060 WIndforce OC 12GB GDDR6 Rev2
PSU : Thermaltake Toughpower SFX 550W 80 Plus Gold Modular
Additional ARGB fans : Thermalright TL-C12CW-S X3
Total Estimated Wattage : 329W
Now, being new to small factor builds it took us some time to have everything put in place and do some proper cable management. For the most part it's done, but still need to find a good way to hide all that clutter from those ARGB fans...
Anyway.
Everything was properly connected, PSU pins, motherboard pins, Front Panel pins, Audio pins, GPU pins.
Then the most expected moment, pressing the power button. Nothing. Only the ARGB from the RAM and the GPU was blinking, but not from any fan.
Both were deceived, but imagine the looks on my sons face..."Daddy...what's going on ?"
I have to say that I was aware when picking the RAM that it wasn't on Asrock's QVL, but I searched completed builds on PcPartPicker using the same motherboard and some people had used that RAM and also other RAM not on the QVL and all seemed fine.
What I have done so far :
- Reseated CPU (all fine)
- Checked all connections (all fine)
- Cleared CMOS
- Tried only one RAM stick on A1, then on B1 slot. Inverted them. 4 possible positions.
Still nothing posting. No fans turning, neither CPU, case, nor GPU fans. ARGB blinking on RAM and GPU.
Tried to isolate the issue...
1. Front Panel Connector : On page 14 of the manual (https://download.asrock.com/Manual/B550 Phantom Gaming-ITXax.pdf) it's number 11. The 8-pin combined cable that comes from the front panel was placed into the 8 pins, starting from the bottom. There's a single pin which is not being populated (top right). There are no 9 pins on the cable, just 8, so I assume that I placed it right.
2. CPU : All placed fine, fan connected to PWM header.
3. GPU : Also all well connected
4. Motherboard : There's a sticker saying P2.30. I have to assume that the BIOS version is correct, which means that I can use the 5600X out of the box. I nevertheless have read about cases where the real BIOS version did not coincide with the "sticker" one. I can't even get into BIOS to verify this.
NOTE : On the mobo box outside I can read : For California only, and I live in Spain. So I'm just wondering... Prior purchase I asked the seller if they could update the BIOS for me since I do not own a previous generation ryzen, but they told me that I shouldn't worry, since they get the motherboards always with updated BIOS...
5. SSD : The Lexar NM790 is a rather recent PCI 4.0 drive. Not sure if that is the issue. I did find a very recent article (24th of July 2023) on Asrock's website about limited support on M.2 SSD's for certain motherboards due to pin mismatch. Lexar SSD is mentioned, but fortunately not my motherboard (https://pg.asrock.com/support/qa/Limited Support SSD List.pdf). I have another PCI 4.0 M.2 in hand (WD SN850X) - maybe I could try that one out. Just wondering if can re-use the thermal strip that was provided for the Lexar.
6. DDR4 RAM : Since nothing is working I have to deduct that the culprit is the RAM in my particular case. I've spent the last 2 hours checking on Asrock's Vermeer DDR4 compatibility list (QVL) and I've come to the conclusion that half of the DDR4 listed there are not even sold anymore....
For even more irony on this, they add a part number and then sometimes a version number behind, for example (CMW16GX4M2Z3600C18 version 3.31). How am I supposed to find this in Amazon ? This is getting ridiculous. Furthermore, as per specification tab for the Vermeer it says that it supports down from DDR4 5100 (OC) , until 3600(OC) / 3466(OC) / 3200 / 2933 / 2667 / 2400 / 2133.... Does this mean that I can't even pick a 3600 Ghz DDR4 RAM unless it gets Overclocked ? I guess that the sweetspot is 3200 Ghz then...just assuming things here.
From the initial 32GB RAM I had planned, I think that I will need to step down to 16GB. Would someone please let me know if I'm ok to go with Corsair P/N CMW16GX4M2Z3600C18 , even though I don't know which version I'm buying ? Or if possible recommend a working RAM out of the box so that we can finally get this little devil to post ? I'm really starting to think that I should have gone for AM5, but for ITX, prices were too expensive imho.
Any hint is highly appreciated, and I do apologize for the long post, but I'm completely stuck right now.
Please also excuse my grammar mistakes since english is not my first language.
Cheers,
Ken
CPU : Ryzen 5600X
Anyway.
- Cleared CMOS
Cheers,
Ken
