Need some direction from the custom cable guys...
loader963
663
569
How do you tell which connectors to order for the psu side of the cables? I’m going to do my first custom set, specifically with a Corsair SF600 and my google-fu issnt coming up with any “list”. Also wouldn’t mind any recommendations on where to shop. Thanks for any tips y’all can throw my way.
2,669
2,793
You need 24 pin, 4 + 4 CPU, SATA power and whichever PCI cables you need for your graphics card, which can be 6 pin, 8 pin or 6 + 2 pin. I got sets from Aliexpress and they work very well. Shipping takes about 4 weeks to the US but the prices can't be beat.
You can also check out Cablemod or Ensourced.
Reactions: Bonk and tinyitx
loader963
663
569
:) I know that lol but my connectors aren’t the same on both ends of the cable. The 24 pin breaks into a 10+18 and for some reason the 8 pin pci for GPU won’t fit in my psu either.
2,669
2,793
That is how Corsair are, any place you order the 24 pin it will be 18 + 10 on the other end. As far as the 8 pin PCI goes make sure you aren't using the 8 pin EPS cable.
loader963
663
569
If I ordered the 24 pin cable it would, but I’m specifically looking for the connectors so I can try to make my own.
As far as the pci cable goes, it is the pci and the plug on each end works in the GPU. Edit: the latch piece that locks cable in won’t line with psu.
