Hi! This is going to be my first SFF build. I've put together a list of parts that I'm considering to get. I'm curious about the fan setup, if I will need all 4 fans (the specs for the M1 said it can hold four 120mm fans). I've listed the Sapphire Pulse 5700XT, but I'm hoping to get the Nitro when it releases. I've seen mentions of shorter wiring with SFF builds for better cooling / cleaner case, what would you guys recommend to get for this build?
Build
Thanks!
Build
Thanks!
