Need Help!
Panchirito
I finished putting all the pieces together for the s4 Mini & my Pc won’t boot up meaning that the motherboard is on but the cpu fan & gpu wont run. I’m new building & hopefully nothing bad happened.
https://ibb.co/c5LsVf
https://ibb.co/hsHT30
https://ibb.co/fEkRqf
https://ibb.co/copxwL
https://ibb.co/eccjbL
https://ibb.co/hVAjAf
https://ibb.co/iG0jAf
https://ibb.co/fRKBqf
https://ibb.co/dQQ1qf
Sorry for so many photos. Just want some one to help me since I’m frustrated lol.
Rankless
49
49
Are you sure your ram and gpu are fully inserted? Try taking them out and plugging them in again.
owliwar
Lazer3D
Apr 7, 2017
586
1,082
the first picture has a cable not fully connected. have you looked over all conectors? sometimes it could be not fully inserted.
good luck on your build
Reactions: brt02 and el01
el01
770
588
Yeah I inserted both and still nothing.
Try the following steps:
  1. Unplug storage and test
  2. Unplug GPU and test system off of integrated video
  3. Reseat connectors on HDPlex (I assume)
  4. Unplug HDPlex and test using standard ATX PSU
  5. Remove motherboard from case and test
  6. Unplug 1 stick of RAM and try it with 1 stick
I think what may be happening is some sort of wiring issue with the power supply (as in some wires required for the motherboard to function properly are plugged in properly but other rails [like 12V to CPU] are not properly wired and the system is confused as to why 5V instead of 12V is being sent to the CPU and the PCIe power for the GPU)
If all else fails, contact ASUS for an RMA on the motherboard (if the above doesn't work)
Reactions: owliwar
Choidebu
"Banned"
Aug 16, 2017
1,199
1,205
Asus strix boards have post leds - at least my b350-i does so your b450-i should too - get the manual and pay attention which led light up during post.
Panchirito
Okay the first picture (link)is what I connected to the Gpu. What concerns me is that it has a missing pin from the 8 pin. Idk if that’s normal or not. I realized that there’s 2 wires in 1 pin if you can see closely in the picture.
https://ibb.co/dfXwRL (picture of missing pin)
https://ibb.co/ifqGRL (what I connected to cpu)
https://ibb.co/kiMyO0 (can see the 2 wires in 1 pin)
The second picture is what I used for the cpu. I guess that will belong to the gpu?
brt02
224
234
Wires look ok to me.... Should have the missing pin
The connector with missing pin goes into the pcie output on the hdplex. The other end of that cable goes into the GPU.
The wire that you've got plugged into the CPU is the right one. Might not make a difference but one end of that cable splits into 2 4pins. That end plugs into the motherboard, near the CPU socket.
Choidebu
"Banned"
Aug 16, 2017
1,199
1,205
For future reference:
1. Test everything connected outside the case, then power it up.
2. Read the manual.
3. Refrain managing cables before you know everything's in order.
4. Embed your images (pls?)
Choidebu
"Banned"
Aug 16, 2017
1,199
1,205
Nope. Still nope.
Look again.
You're wiring the p_led to hdled. And pwrbtn to reset. Yes it turns on but it's wrong.
So pwrbutton jumper turns on the pc when it's jumped (connected). P_led turns on the light in your power button when the pc is on.
After that the boot device. Of course. You go ahead and put windows or linux in now.
Panchirito
Nope. Still nope.
Look again.
Got it thanks! Where can I get it to boot? Because I won’t be able to use any optimal drive
