Hello there
I am planning to downsize my workstation from the beloved Meshify c to the Cerberus x, but there seem to be some hardware compatibility issues that I can't figure out.
Currently, I have an Enermax 360mm tr4 aio in my meshify c, but will have to downgrade to either a 280mm or 240mm rad (I might just cut off the hose and connect the pump to the new rad to save money); Also, I have a titan xp with a 120mm aio & nzxt bracket installed. Besides that, I would like to at least fit 2x3.5 hard drives and 1x2.5 ssd into the set up.
On top of the compatibility, I am also concerning about the performance degradation of my TR 1950x. will the 30mm 280 rad or 45mm 240 rad perform a lot worse than the 360?
To make it easier, I will list my parts below:
CPU: amd threadripper 1950x
COOLER: enermax tr4 360 (w/ refilled coolant)
MOBO: Asrock X399 Taichi
RAM: GSKILL RIPJAWS V 16GBx4
GPU: titan xp w/ nzxt g12 & evga 120mm aio (3 slot total depth)
PSU: evga 1000 G3 (150mm length)
SSD: 2xNVME on the MOBO, 1x2.5
HDD: 4x3.5'' 8tb SEAGATE
FAN: 4xNoctua A12X25, 2xNoctua A14 (that is all I have available, not planning to buy more fans)
Picture of my current setup:
Purpose:
1. CPU properly cooled
2. dual-rads, 1x2.5ssd & 2x3.5'' hdd can all fit in the case.
I am new to the SFF world so your opinion will be worth a lot to me. Please help!
Purpose:
