FAQ
Q: When/where can I order the M1?
A: The M1 is now discontinued as of October, 2021.
Q: Will x fit?
A: See the specs towards the end of this post. Also see the GPU compatibility list.
Q: Which parts are backward compatible?
A: The following parts from V6 are backward compatible with older versions:
M1 V6 User Manual - see end of this post
M1 V6 changelog
Renders
Full Specs
M1 V6 User Manual
Other resources
Q: Will x fit?
- Exterior panels
- Front I/O bracket w/ports
- Side fan bracket
- 3.5"/2.5" and ODD drive brackets
- Motherboard tray
M1 V6 changelog
V6.1
Chassis
-Adjusted front SFX mount position
-Adjusted 2.5" mounting holes
-Adjusted 2.5" drive SATA connector cutouts
-Added threaded standoffs to fan bracket mounting holes
Front I/O
-New punch tooling for smoother edges
SFX bracket
-Added/modified flanges to mitigate possible PSU movement
ODD bracket
-Adjusted 2.5" drive mount screw holes for improved stacking bracket support
-Added chassis mounted 2.5" drive screw access holes
-Adjusted aux chassis 2.5" drive screw access holes
Parts box
-Removed 120mm fan filters
-Fan grille count changed to 2
-Adjusted screw counts
Power cable
-Changed to right angle
V6
Front I/O
-Added USB Type C port (requires motherboard 20 pin Key A header, see list)
-Changed headphone and mic ports to single combo jack
-All ports use new molds
-Redesigned I/O bracket with swappable no-I/O faceplate (ports can be removed for cleaner look/slightly better 2.2+ slot GPU compatibility)
Chassis
-Redesigned ventilation holes on bottom and rear to improve airflow
-Added longer fan mounting slots on the bottom
-Bottom vents moved to separate steel floor plate attached to underside of chassis
-Added bottom magnetic dust filter
-Threaded inserts on PCI bracket
-Added M4 screw holes for window mounting to chassis
-Front-right chassis flange reduced, SFX PSU can now be installed from the right side
-Reduced rear-left chassis flange to facilitate GPU installation
-Enlarged chassis front GPU passthrough to facilitate GPU installation and provide more room for oversized GPUs
-Removed four panel mounting clips from side flanges to reduce incidence of oversized GPU conflicts
-Changed front 2.5" drive mounting to use screws instead of rubber grommets to save space/reduce complexity
-Integrated fan bracket mount into chassis flanges
-Added inside-front mounting for SFX PSU
-Added Kensington slot to rear
Fan bracket
-Added more and longer 120mm fan mounting slots for greater range of mounting
Motherboard tray
-Changed to removable standoffs
ODD bracket
-Redesigned to single piece, now supports 9.5mm and 12.7mm ODD drives
HDD cage
-Redesigned to two pieces, now supports 2x 3.5" drives *or* 3x 2.5" drives; now allows mounting to inside front 2.5" mount (3x 2.5" configuration only)
Top panel
-Changed to 2mm thick
Side panels
-Extended ventilated area adjacent to GPU
Other
-New 15mm tall molded rubber feet
-New adjustable GPU support bracket (adjustable for 2-2.5 slot cards)
Chassis
Front I/O
SFX bracket
ODD bracket
Parts box
Power cable
V6
Front I/O
Chassis
Fan bracket
Motherboard tray
ODD bracket
HDD cage
Top panel
Side panels
Other
Renders
Full Specs
Volume |
External Dimensions |
Materials |
Front I/O |
Motherboard Support |
CPU Cooler Support |
Graphics Card Support |
Drive Support |
Fan Support |
Liquid Cooling Support |
Power Supply |
Other resources
- User builder gallery (M1 V5 and earlier)
- NCASE M1 Discord server
