Hi all!
This build is the workstation I am using at home when I am not at the studio. I need a fast multi core cpu, a beefy gpu and multiple storage options. I also want it so be quiet. Nothing more embarrassing in front of the apple guys, than if you go ITX on pc and have a machine that sounds like it is going to take off like a rocket.
The original machine with CPU and motherboard is back from 2019. I switched around a lot with the Noctua coolers, fans and cooling layouts. I always setup the classic (not good) airflow with bottom in and rear out, so that I can make use of the dustfilters. And wanting to have an HDD makes things just more complicated..
From a small Noctua NH-U9S (that was just miserable) to a kind of Vintage NH-C12P (that allowed for HDD install with the ncase mount) to the C14s. Because it is bigger. With a 140mm fan below and a 150mm fan on top the cooling is really good. Almost dead silent under full load (a few feet away). I switched to the slim 120mm fan on topto be able to close the case. Cutting out would look cool but what when I want to switch motherboards?
I believe my ncase has reached its final form.
almost.
I designed a PSU + HDD bracket, that holds the HDD on the height of the mainboard. This allows for a large 140mm fan below the cooler. (in contrary to the SFX standard mount position). The PSU sits closer to the GPU. Some custom short cablesmake it look cleaner, but it would also work with the original cables. I also use those sketchy adapters!
Looking good so far, GPU is finally silent (asus TUF wtf?!) Still waiting for a power cable and the last print with some minior adjustments. Then I will finish and clean her up. And post some pictures.
Thank you for reading!
Log - Two dead CPUs, 95°C and 100 decibel - My Ncase M1 Ryzen Journey
well, not really 100 decibel. That was just for clickbait. But I had two Ryzen Processors DOA. Chances of that happening are so low, I guess I must have destroyed at least one of them, although regularly grounding myself. This was how my Ryzen experience started. tldr: go for a few large...
smallformfactor.net
almost.
NCase M1: HDD 3.5 + SFX mount compatible with ALL CPU coolers and GPUs
This HDD mount is compatible with ANY CPU cooler configuration and ANY 4-slot GPU you can throw at that case. You can also mount the NCase side bracket with dust filters or use those sketchy 180-degree GPU power adapters! https://www.thingiverse.com/thing:5568904 This is the development...
smallformfactor.net
