Advice Ncase M1 fan filters
Soul
I just saw the revision log for v6.1.
  • Chassis
    • Adjusted front SFX mount position
    • Adjusted 2.5" mounting holes
    • Adjusted 2.5" drive SATA connector cutouts
    • Added threaded nuts to fan bracket mounting holes
  • Front I/O
    • New punch tooling for smoother edges
    • Audio combo jack changed to black
  • SFX bracket
    • Added/modified flanges to mitigate possible PSU movement
  • ODD bracket
    • Adjusted 2.5" drive mount screw holes for improved stacking bracket support
    • Added chassis mounted 2.5" drive screw access holes
    • Adjusted aux chassis 2.5" drive screw access holes
  • Parts box
    • Removed 120mm fan filters
    • Fan grille count changed to 2
    • Adjusted screw counts
  • Power cable
    • Changed to right angle
Does this mean the dust filter is not included in 6.1? From one of the pictures, the dust filter seems to be included and I am confused.
Necere
NCASE
3,284
It does not mean that.
Older versions included some plastic-framed 120x120mm fan filters for bottom fans:
(Middle right)
With V6 I redesigned the floor of the case to include a steel grille with magnetic filter (much like the fan bracket), so the old filters were no longer needed.
Soul
(Middle right)
Oh! Okay I see. Thanks for your reply!
Dust is a huge problem for me as my GPU is a blower card and super difficult to clean. This makes me comforable to buy the case now. Expect an order soon! :)
