I'm currently contemplating going custom loop in my NCase M1 V6 and had the following in mind:
I have a 9700k and 2080S so I was thinking an XSPC 240mm Ultrathin rad in the bottom and a 92mm Nemesis GTX in the back should be sufficient. Now here's where things get interesting:
- @HottestVapes You mentioned that the EK Waterblock wouldn't fit because it would hit the sidepanel, however I think that only applies to the Vector model and not the Classic model. The Vector is indeed 127mm but the Classic is 123.8mm. See this diagram. Furthermore, I think this is also the thinnest waterblock out there and it would allow me to fit 25mm fans between the GPU and Rad, instead of 15mm fans, which should hopefully help improve cooling performance.
- The 92mm Nemesis GTX in the back is 54mm deep. I wonder if I could stil fit a 25mm fan onto it and still reach the CPU waterblock behind it. If not, I would stick with a 15mm fan.
- For Pump/Reservoir I'm thinking about 2 different options, but both would involve the EK SPC-60 pump. It only requires a PWM fan cable for power, no Molex required. It is very quiet and performs roughly around the same as a D5 pump on the middle power mode (mode 3). Now, either I would go with a 100mm or 140mm EK-RES top and mount the pump horizontally in the front of the case or I take the EK SPC-60 pump and mount it onto an IceMan Reservoir on the back of the case. This pump seems to have the same measurements as their DDC pump so I'm hopeful it would fit on the IceMan.
- If the EK SPC-60 fits on the IceMan reservoir, there's still the challenge of the 92mm Nemesis GTX radiator mounted on the inside. Assuming the IceMan that I'd order today has the 92mm mounting points, could I for isntance use some longer M3 screws, e.g. M3x80mm and have both the IceMan reservoir and the 92mm rad mounted at the same time?
- If the above wouldn't fit, I would drop the 92mm radiator and go for a 120mm radiator on the right side of the sidebracket. This would still allow me to more easily build the loop and have easy access to the motherboard area on the open left side of the bracket.
Thoughts?
Measurements look good for that EK block, should fit without issue.
I'm not confident that the 92x54mm rad will comfortably fit with a 25mm fan and the tubes exiting the CPU block judging by how close it is with
this 92x45mm radiator. It will depend on the socket location on the motherboard, and the CPU block you use. I've seen a
low profile Alphacool block that should make it a non-issue as it allows for the tubes/fittings to exit the side of the block. Could be an option for you.
As for the TX240, it should fit with 25mm fans, I'm still on the fence on whether to replace the rad or the fans in mine. Actual cooling may be indentical between 15mm fans plus 30mm rad and 25mm fans with the 20mm rad though, haven't seen too much on that besides one users first hand testament on using both set ups.
I've seen D5s and DDC pump/res combos fitted to the front of the case, unsure on the overall size of them but it should work. However, I don't know much of anything about that particular pump. I'd suggest reading up on it and if it's fully compatible with DDC tops and reservoirs.
I'd recommend not using the 92mm rad on the rear in conjunction with an Ice Man reservoir in any case. Even offset and spaced away from the radiator, you'll run into issues trying to pass the tubes through and into the case.
I think a better option if you're set on the SPC pump but find out it's incompatible with DDC parts is to put a T or Y fitting on the pump inlet, along with a QDC or tap so you can hook up a tube or mini res to the pump, fill the loop via that and then disconnect it once you're done.
All that said, I'm definitely no expert on the intricacies of a 92mm + 240mm loop in the NCase. It's a bit of a different beast compared to dual 240mm loops.
