My almost complete Dan A4 v4 build!.
M-jeri
124
82
Hello.
Pictures first:
Specs:
* Ryzen 3700X
* ASRock X570 ITX TB3
* 32GB Trident RGB RAM
* 2TB 950 Pro SSD (m.2 Thermal pad on the way.)
* 2TB Crucial 2.5" SSD. (Hopefully, the low profile SATA cable will allow me to connect it. Otherwise would be a huge issue for me.)
* EVGA 2080Ti XC
* Corsar 750SF
* Asetek 645LT
* /u/Losercard from reddit's Ultimate cooling kit. The PSU and GPU is raised using custom brackets for this.
Afterthoughts:
One thing I should have noticed is that the SATA connectors were right angle and its so so close to the PSU. Getting these now:
Or.
M.2 temps are bit high, so getting this:
Did you catch the way I kept the cooling pipe down? Is that Ok? Or anything you would like me to try or change for the better?. First SFF build. So go easy on me please. :)
Thanks.
