enricko7 submitted a new resource:
Mount Plate for HDPlex 400W DC/ATX module - Intended for use in NFC S4M
This plate is to be attached to the backplate of the HDPlex 400W DC/ATX unit. It can then be rigidly attached to the inside front panel of the NFC S4M. Use 90 degree countersunk M3 screws in 4mm length for best results.
ZIP Folder Contains:
- .STEP 203
- .dwg file (for SendCutSend)
- Solidworks Part
- Solidworks Drawing
Changelog
R2
- Change material thickness to 2.6mm. This allows proper thread engagement when attaching to the S4M. When cutting, use this as a minimum material thickness...
