Resource icon
Power Supply Mounting Plate for Panel Mount 6-Pin Molex Connector 002
enricko7
95
50
enricko7 submitted a new resource:
Mounting Plate for Panel Mount 6-Pin Molex Connector - DC Power Entry module for the S4M using a Panel Mount 6-Pin Mini-Fit Molex connector.
This part is intended for using the HDPlex 400W AC/DC unit as a power brick for the S4M. A 6-pin Molex Mini-Fit Jr connector installs to this plate on the rear rectangular cutout. The 6-pin DC output of the HDPlex 400W AC/DC unit then plugs into the panel mount connector, which is connected to the DC/ATX unit inside the enclosure. This part could be used on any case that uses a similar cutout pattern.
5000 series Aluminum in 2.6mm thickness works well for this part. Warping when laser...
