Morex 2799 Sleeper Build log - 5.4L (ADVICE/CRITIQUE NEEDED!)
Vlad502
258
211
I've noticed that when people do case fan mods with two or more, the fans are literally next together. I was wondering if there was an advantage for this besides space saving. Here is an example with Metis.
I think the capacitors on the Asrock B550 Phantom ITX board might fit. I found this post on twitter which shows that they are slightly smaller then the PCIE slot.
Probably for mounting water cooling radiator too
After mension it i watched some youtube reviews and all looking same way (boards not reviews)
Analogue Blacksheep
850
706
