Update 3 Mar 2018
- Prototype arrived.
- Kit for water cooler.
- Kit for SFX PSU.
- Kit for increasing CPU cooler height.
- Add bending and CNC production method.
- Add more 2 model in series:
All models are same type, only dimensions are different.
Model L support Full Length GPU and internal SFX PSU:
Model S unibody aluminum with 3L volume is world smallest ITX case that can hold ITX board and Gaming GPU card (1060 and up).
MODEL M Prototype:
My fabrication method work excellent:
See all image : https://flic.kr/s/aHsku2s4jK
Some change:
Kit for SFX PSU:
Kit for increasing CPU cooler height and water cooler (mounted side panel):
I will not test thermal performance because sure it better than other case (see ventilation system) and the MB in image not working.
I also provided bending version with same price. Look same but no screw in front panel.
- Kit for SFX PSU.
![](https://i.imgur.com/DkeGd3F.png)
![](https://i.imgur.com/T8q1Fbs.png)
MODEL M Prototype:
![](https://i.imgur.com/XqcbjmU.jpg)
![](https://i.imgur.com/JMksrHy.jpg)
![](https://i.imgur.com/KxWSh3t.jpg)
![](https://i.imgur.com/AI6jB3T.jpg)
![](https://i.imgur.com/kYin1i3.jpg)
Some change:
Kit for SFX PSU:
![](https://i.imgur.com/QYBLtME.jpg)
![](https://i.imgur.com/UchiI7A.jpg)
![](https://i.imgur.com/3XmfIgo.jpg)
Note: 100$ starting price for carbon steel version.
Update 14-02-2018:
-Change some design for premium looking ( Picture will be update after finishing prototype).
-350W Internal PSU solution for both 110V-220V system.
-Add feet.
-Remove aluminum model, add carbon steel powder coated model.
First monster in my series monster ITX S arrived, ready for order with the starting price just from 100$.
Specification:
Size:336x220x68mm (Without feet)
Max VGA L: 215mm.
Max CPU cooler H: 50mm.
4 x 60mm fan slot.
2x2.5" drive.
Support inside PSU: (Hdplex AC/DC 300W + Hdplex DC/DC 400W) or my PSU solution (350W AC/DC + 24pin DC/DC +12V Semi conductor Breaker).
Special: Hdplex AC/DC 300W +dual HDplex 160W nano, this configuration allow you to install 215mm GPU with fully inside PSU.
Material : Carbon Steel or stainless steel with Acrylic or glass top and bottom.
Finished: Sand blast (Stainless steel) or powder coated (carbon steel).
Color Silver, Black
Design:
https://flic.kr/p/222xb2y
Production technique: (Update, change the way to hook the sheets)
I'm thinking too much to find a good price and quality solution and I found a technic that I called "LEGO FABRICATION": the new way is hook the sheet by sub plate and some screw so don't need welding, case can be easy to disassembly.
this one allow us to connect any plate without screw just small welding to fix, so we can easy produce in small quantity.
Mount standoff to bottom plate by flat screws.
Power plug solution is 4pin ATX male, it's small and popular one, each case including 4pin female to standard AC power cord cable.
by this technique, the products will be easy to be produced with good price and quality.
Any information about each batch will be informed to you. If you have any question please comment .
