Hi all, I'm starting my first true small form factor build (I have done a fair few Mitx builds, but just cause they were the cheapest option at the time).
I want to take most, if not all, of the performance from my EATX workstation and cram it into a Dan Case A4.
I'm pretty happy with the case, looks easy enough to build in, but I am worried about CPU cooling. My room can reach 40 degrees C ambient, and while I've never had a problem before, I am not expecting a Noctua L9i to keep up with a stock-clocked (probably undervolted) Coffee Lake Refresh i7/i9.
I also don't like the Asetek AIO and the space it takes up.
So my proposal - cut out a hole in the side panel for a tower cooler to protrude from. Inspired by this RAM cutout from Linus Tech Tips small form factor build: https://i.imgur.com/6oH9Sj1l.png
I was thinking either an L9i with a thicker fan or preferably an L9x65 also with a thick fan. Then enclosing it all in a chimney with mesh on the top. My current case is a Thermaltake Level 10GT, so I don't mind asymmetry but would like it to be as aesthetically pleasing as possible. I unfortunately lack the tools or the hand/eye coordination to do it myself, but assuming I could find someone who did, would it be feasible for improving cooling?
