I noticed that many people are looking for this cable
90 Degree Left Angle PCI-E Adapter Cable
Can be found at KareonKables.Com
^That does appear to be built tougher than the heat-shrinked version.
I am not the seller. Internal cable damage after multiple flexings could be a concern due to the removal of the strain relief portion of the Mini-Fit Jr connector. To alleviate this, the heatshrink could be replaced with (or augmented with) potting the upper portion of the connector in epoxy or silastic. A removable temporary plug would be needed to prevent the potting compound infiltrating the lower portion of the connector.I know the exact measurements of this cable, this guy can into the county with product dumping and stole my design from eBay. It is the exact same measurement in height, except it is made with the cheapest parts known to man! Call him on the phone, I was curious how he could by the parts and pay the shipping until I heard his voice. He advertises an ultra-low cable, except if you bent a Molex crimp connector the get the same height as the cables that I make without a backbone to lash the wires to, when it is bent the other direction a fraction, the crimp snaps as well. You have to remove the heat shrink to see the fractured terminal. If you look at the two side by side you will see that they are the exact same height, unless the guy that I am talking about is you?
Wouldn't it be pretty simple to create a pcb board in with a female pcie power connector and a male that allows you to route the power cable above the GPU?
I purchased an 8pin one few months ago. Works like a charm.^That does appear to be built tougher than the heat-shrinked version. I'd be interested in trying one.
Somewhat off topic, can you do custom stuff? I wouldn't mind a custom harness for the Seasonic 300SUG modular Flex ATX.
^That does appear to be built tougher than the heat-shrunken version. I'd be interested in trying one.
I see. Evga does have one but I'm guessing it is custom design only they can order. http://www.evga.com/articles/01051/evga-powerlink/The issue is that there isn't board-mount Mini Fit Jr. connectors with female terminals.
The Powerlink does not use PCB-mount headers, it uses full-size plugs with the wire crimps replaced with custom 'unitary spade' connectors that join to internal rails.I see. Evga does have one but I'm guessing it is custom design only they can order. http://www.evga.com/articles/01051/evga-powerlink/
They exist, the trouble is tracking them down with the correct number of pins, and keyed correctly for PEG. If you have a MOQ of several tens or hundreds of thousand you could probably call up Molex and get them, but otherwise you're reliant on some other manufacturer having the same requirement, and surplus stock making its way to resale.The issue is that there isn't board-mount Mini Fit Jr. connectors with female terminals.
