Other Mini itx + DC to POE + POE switch?
denywinarto
Has anyone tried to power up a low powered mini itx with POE switch, using DC to POE converter?
I was wondering if it's possible to do this on gemini lake boards such as beelink / liva.
Since they only consume <10 watts a single POE port should be able to power it.
The question now is if it's possible to do it with DC to POE converter,
Planning on doing this for 20-30 units powered by POE switch if possible.
denywinarto
Not an EE, but according to wikipedia, the voltage of standard POE variants is 37V - 57V, which is outside of the normal range of DC inputs for small PCs (~19V).
https://en.wikipedia.org/wiki/Power_over_Ethernet
So yes, will likely need to convert the voltage.
Thanks for pointing this out,
would something like this work?
http://s.aliexpress.com/B3aa6jI3?fromSns=Telegram
I dont see it mentioning voltage conversion..
I plan to use along with this, cause POE switch is expensive
http://s.aliexpress.com/VZrINfUn?fromSns=Telegram
denywinarto
Perhaps someone would be kind enough to test powering up their apollo/gemini nuc using something like this ?
https://www.ebay.com/bhp/poe-splitter
I don't have any gemini/apollo nuc right now so i cant test this.
It's cheap so I could probably buy it for the tester if somebody's willing to test it
E-Rod
23
39
Charlotte, NC
There are a few PoE splitters that support 802.3at (PoE+) inputs and can output 12V/19V/24V.
The NUCs use 19V inputs, and I believe the DC-ATX power supplies do as well.
You just need to find a PoE splitter that can output 19V, which the one listed doesn’t seem to do.
Reactions: jtd871
denywinarto
I
Hmm apparently generic chinese poe splitter uses different dc socket connector with intel nuc.. im having trouble finding the one that matches nuc's.. it has to be 2.5mm ID 5 5mm OD otherwise it wont fit.
Secondly it has to be active POE, passive wont work, im ordering a custom splitter from alibaba..
Third problem is they are quite expensive.. maybe thats why its not popular, with that price point, it wont have any benefit over non-poe, maybe only if the electric cost in your country is very high
