Hi there!
My first case was a cardboard-case and it was really reliable for around 15 months of traveling mostly 3 weekends per month. Here is a Video if you are interested... it is german, but you can see the "fully gaffered" cardboard-case.
... my goal right now is, to re-create this kind-of case, at least regarding it's "dimensions".
I have spent tons of hours for searching for a case that fits my wishes, but didn't found anything. Because ALL must fit into a 85L backpack, the dimensions are really important. it's ok to be looong and a bit wide but therefore NOT too deep, because otherwise it will crash the display that is in the backpack, too. As a visual artist I do want to be able to have two GPUs, for getting as much projectors and LED walls connected as possible. So, I do need to stay with mATX. Then I found the Orthrus-Project, but wasn't able to find anything like this that can be bought.
So, last but not least I came up with my conclusion to build an own case, something inbetween the Orthrus and my Cardboard-Case (which is gone since some weeks, because of stability-reasons after 15 months) - right now I am using Sharkoon CA-M but I don't want to use it way longer, because of the dimensions and the resulting pressure in the backpack that leads only to one half of my mobile 19'' TFT display... the cardboard-case was great, because it had the same size as the TFT and wasn't really thick (as you can see in the video), so the pressure was low and spread all over the TFT, no need to worry about damages.
So... I need to decide...
Shall I go for cardboard again, but this time more stable cardboard? would that be possible?
Shall I go for a wood case made up of thin wood-plates?
Can you help me regarding best fitting materials for those cases?
best wishes from western germany,
Dennis
Dennis
