Advice mATX case recommendation
Covuk
73
75
I'm building a Pc out of my unused parts and looking for the most compact possible mATX case considering the following:
Must fit an ATX PSU
Up to 330mm GPU (with an ATX PSU fitted)
Preferably Silver, Black if not.
Mesh sides, not windowed.
Small desktop footprint, but prefer front mounted PSU like the NR200/AP201 to keep overall height lower
Any suggestions please?
tinyitx
2,279
2,338
Meshroom S (the only minus probably is its height?)
Covuk
73
75
Yeh, the NR200P is looking like the best option , even having to buy the ATX bracket.
Was hoping for something like the silver Dan C4 only mATX and with ATX PSU compatibility
tinyitx
2,279
2,338
NR200P, according to its product page, does not list mATX mobo as supported but the max size is up to 244x226 only but not 244x244. And, its spec does not list ATX PSU but only SFX/L. Beware!
SGPC K88 almost fits all your requirements except it has a windowed side.
Covuk
73
75
They actually sell an ATX PSU bracket for the NR200....
Looks like I might be waiting for the Dan C4v2, as Dan is working on mATX compatibility for it.
Reactions: Arboreal
