Im in the process of designing a 3d printable frame like the PurePC in the build logs section for a case and was trying to figure out how to mount a reservoir and came to the conclusion that I don't want a standard reservoir and would like to CNC some acrylic that could be put inside of the frame and mount a pump to it.
Has anyone here ever made their own reservoirs? What thickness acrylic would be good for this and should I just use an epoxy to seal or should I look into some silicon cord to make some o-rings? How should I do leak testing on it to make sure it won't fail?
If this works out I might make a connector block and not use fittings, much like the ekwb terminal outlet/inlets.
