Production M2427 - Cable Management Freedom
BaK
981
964
(What is "double crimp"? Crimping a molex pin to each end of a wire?)
Two wires crimped into one terminal:
(the terminal on this pic is not the kind used for the 24pin)
http://web.cecs.pdx.edu/~gerry/class/EAS199B/howto/LCDwiring/female_block.html
Antioch
52
Thank you for taking the time to research this and report the findings.
I'll have to research this and hopefully address in REV2.
Otherwise, is it working as expected? If you do need that feature, give me a PM and we'll work from there.
I know it's only been two weeks, but I wonder if any progress on diagnosis this has been made? This is an excellent mod and I'm considering buying two of these, one of which I would like the "OS shutdown with reboot on power loss" feature working as intended.
I'd also like to make custom length wiring for mine, which means removing the set it comes with. However, I'm not familiar with the connector used to attach the 12V and GND wires to the board. Would you please share more information about this?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
It'd have to address in R2 which will be a while but it is on the list of features.
For modifying it, you need some basic soldering work. You can splice and extend the wires using butt connectors or solder extensions. You can also remove the stock wire by desoldering it. Primary current wires are just soldered after being crimped together. The other wires are connected to JST EH series connector, 3 pin. You would need some basic crimping skills.
What cases are you using btw?
Retrias
157
77
so this is basically a power distro board that can include sata power into one module so you dont have to plug all of them to your PSU ?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Correct. Essentially a Picopsu that is designed to work with your atx based power supply. It still requires you to use your gpu and cpu power connector separate, as those draw a lot of current.
Is it possible to make one that can fully Distro a system? Yes. But it requires a big pcb, and gets quite more expensive.
Reactions: BaK
Antioch
52
I can crimp, but am more worried about the butt connectors -- have never worked with those. Any recommended connectors I should use for those? (Prefer not to do extensions as they're not as clean, heh)
One is a Dan A4, the other is some micro server case I modded.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
They are just cylinder pieces of metal that allows you to crimp one wire on one side and another wire on the other side. Or you can twist them together and do a single crimp piece.
Then you cover the open conductor with some heatshrink tubing. It'll be stiff at the location of the crimp but it's pretty non hassle as far as amount of work goes.
The pinout are labeled on the pcb so you should be able to determine which wire with which.
If possible, please post pictures. I'm sure there are a lot of lurkers interested!
Aranii
What is your approximate timeframe for releasing the 2nd revision? Would they be shipping by the end of November?
Antioch
52
... Primary current wires are just soldered after being crimped together...
Sorry, this is what I wanted to know. How are the ends of the primary current wires crimped together before being soldered to the board?
Kilrah
128
112
Is there an idea yet of whether the reboot on power loss thing could be a DIY fix on the board?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
They're just a simple crimp that makes it easy to solder two wires. You don't need it. You can twist two wires and just tin it, or just simply solder them as is.
srekal34
132
127
Is the platinum version backwards compatible with gold? Currently I have gold, but I would like to upgrade in the future without changing the adapter.
andornaut
Those who have gotten a chance to use the platinum version, how has the experience been?
Seems to be working well so far. I haven't run under much load yet, though. I definitely appreciate the extra room in my Ncase M1
Btw: I spliced the 12v wire to the sense wire instead of double crimping or routing to an open PCIe terminal, which seems to work fine.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Sweet. Can you post a picture for others to see how it looks inside the M1?
Antioch
52
Yeah, I know I could do the normal twist and solder, but I would love to know what that crimp connector is. It looks so clean. Do you have a name/part number?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
No I do not. I thought it was interesting too. It's essentially a very short crimp with no male/female pin. So i guess you can just use any crimp and then snip off the pin part.
Reactions: Antioch
