LZ7 #8 High End Build
cmyk78
384
432
cmyk78
384
432
I teased earlier about a how I had put a NH-U9S in here, and here is the update.
Isn't it beautiful. @K888D sent me a new front panel in December and I've been to busy to take pictures until now.
There it is, the NH-U9S!
An external sfx psu, @MarcParis will appreciate this!
A closer look at the cables coming out the back.
Now we can see the NH-U9S!
Here you can see the fitment of the cooler and how I routed the cooler.
My eventual plan is to put an EPP-400 ac-dc converter in here with a G-Unique plug in.
That box represents the EPP-400 plus 5mm standoffs.
You can also see I've removed the USB ports, in preparation of the EPP-400.
This is where I'm going to need something custom. I'm going to have the ac inlet to the right of the NH-U9S.
K888D
Lazer3D
Feb 23, 2016
1,473
2,938
www.lazer3d.com
Looking good!
The EPP-400 power supply you've mocked up looks pretty close to the front Noctua fan, would it be beneficial to swap that front fan for a NF-A9x14 and free up 10mm?
What do you plan to do about the big hole in the rear panel where the SFX power supply used to fit?
If you wanted I could do a custom rear panel for you that you could order through Ponoko?
