CPU Low TDP CPUs and Gaming?
KMPKT
3,382
5,934
I would really love to see the site do a definitive workup on what the real world implications of T chip vs. under lock vs. undervolt are across a series of real world benchmarks. I'd be willing to loan my 4690T if it would help.
TheDreamingMonk
62
48
I've actually been heavily thinking about grabbing the i7-7700T for my new build. Currently using an old i7-2600K @ Stock, and since I've long given up overclocking I see little benefit to buying a K series chip. Though the 4 cores + hyper threading are extremely useful for a lot of what I do. I may not see a huge performance boost, if any at all, but the 35w TDP is so tempting seeing as I'm looking to get an NFC S4 Mini in the next batch. Just about any low profile cooler like the L9i or C7 will have absolutely no issues with them being rated for 65w+. Would make for a pretty good system paired with a GTX1060 or GTX1070.
Would be nice to see some performance tests with them either way.
I plan to do this eventually, since I have a 6400T.
I figured a 6600K is close enough if I can get my hands on one at work.
CC Ricers
2,216
2,522
I'm currently running a system with a i3 4130T and a GTX 1050 (non Ti) and it does fine with most of the gaming I do. For power I use a 160W HD-Plex DC board with a Dell Alienware 150W power brick. So the limit is with the power brick, and looks like it doesn't come close to its max wattage.
As others have said, four threads is enough overhead for gaming. The downside to my i3 is that it can't turbo boost for 1 or 2 threads. Kaby Lake Pentiums would though.
Also, you might actually notice a performance drop more in older games that don't take advantage of multithreading, like Source games such as Portal or TF2.
aquelito
Piccolo PC
Feb 16, 2016
948
1,116
According to SilentPCReview, there is not that much power consumption difference between an i7 6700 and i7 6700K.
The difference between the 6700T and 6700 may also be negligible ?
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,801
4,127
guilleacoustic.wordpress.com
Well, this is Haswell era .... but i7-4765T vs i5-4670K is relevant I think
Power consumption:
Annual cost for 6 hours a day usage:
Kilogramm of CO2 per year / 6h a day:
TheDreamingMonk
62
48
Normal and K series don't have a huge difference anyway. K series chips normally just have a better boost performance. If you don't hit that boost, their power consumption won't be all that different.
The T series idle, should be lower still, and maxing out at 35w will definitely put a dent in overall consumption.
cleveland
453
234
+1 on that, Sir.
