Louqe Ghost S1 with hardline tubing
b1ackwid0w
30
41
I have two 2.5 inch SSD tuck behind PSU.
This is the first time I build my own custom sleeved cable and it took me 30+ hours.
The temperature is 85 full CPU load at 4.6GHz (8700k) add the titan xp can heat up CPU to 90 and the GPU max out at 82
I got those temperature after an hour of stress test and the fan has been set complete silent. around 700rpm
It barely fit in my pelican case
2,719
2,854
Looks great, glad to see you did a build log. I went the lazy way and got some @pslate custom cables, sure does make a difference. Can I ask which fans are you using?
BaK
981
965
Whatch out the housefire, dude...
This^
Thought the same when I saw your pic, you should have added some heatshrink tubings to isolate the naked wires:
b1ackwid0w
30
41
This^
of course. the picture shown was just the test fit I sleeved all wires and heat shrinked the joint after the picture was taken.
