Thank you in advance for any advice, this will be my first SFF build and I am looking forward to it.
CPU: AMD Ryzen 3700X/3600 - Can't decided which would be better for temps with my air cooler. I don't really plan on overclocking at this moment in time, I do plan on undervolting to lower temps if possible. (Plan on doing gaming and content creation on YT)
Mobo: ASUS X570-I/ B550i - Debating which would be a better fit for my CPU Cooler.
CPU Cooler: AXP 100-Copper/ID Cooling IS-60/ NH-L12S - Really just a toss up to which would be better and would have less fan noise as well with good temps and fit easily and comfortably in the Ghost S1. I will be switching out the stock fans of these coolers with the 15mm Noctua Chromax Fan.
GPU: 2070 Super - Really debating on which brand GPU would be better for noise and temps in my Ghost S1, I do plan on undervolting, any advice in this area would be welcome.
RAM: 16GB HyperX Fury Low Profile 3600MHZ DDR4 CL17
PSU: SFX 600 Wat 80 Platinum
Storage: M.2. 1 TB SSD
Thermal Paste: Thermal Grizzly Kryonaut
If you also have any first time builder advice as it pertains to building in a Ghost S1, I'd appreciate it. I have done a lot of research and watched a lot of video's on youtube.
