Enclosure Looking For Smallest ATX Case
oanmerri
I've been searching a lot for the smallest atx case I could find and found realan E-D3 at 23 liters. The case isn't the best but it is windowed, which I like. Does anyone have any suggestions? Money is no problem. Preferred to have window and around 25 liters or smaller. Support for reference cards, or bigger is fine. Thanks in advance.
dagathon
Thermaltake Core G3 is 23.6L and has a window. There is also the Riotoro CR1080 which also has a window, but I'm not really a huge fan of the window design on it.
EDIT: Thermaltake, not Thermalright...
Overtek
335
555
UK
www.overtek.co.uk
Hmm,
Let me throw this in there for your feedback. No beauty pagent winner, but as your only after mini ITX with ATX PSU. Then this is 9.952L
All depends what you want really.
If there's any interest I'll progress some pricing etc and answer the obvious question that I will be asking about this...Where the hell does the mains lead enter or leave for the PSU.
Any how if its small you want it is what it is.
pic 1
pic 2
pic 3
pic 4
pic 5
Case Dimensions : 39 x 8.8 x 29cm D x W x H
Mobo Support: MicroATX 244(W)x210(D)mm or Mini-ITX
Drives 1×5.25″ exposed , 1×3.5″ hidden
Cooling 60mm Top Cover Fan + 60mm Bottom Fan x 1 pc
Front I/O Ports
2x Front USB + Audio in/out
PSU support
: ATX Power Supply
Expansion slots: 4 low profile
