Concept LESS Case - A completely toolless, Full-size PSU capable SFF case
RoWe90
LESS CASE
A week ago, i posted a concept of this case over on /r/sffpc (link)
As well as an update to that initial design (link)
At that point the case was a personal project, but as the feedback was rather positive and there seems to be some interest in the community for getting their hands on this, i since refined the case and made some changes to fully flesh it out.
As this is still a WIP, the here mentioned numbers are not final, and there is still a lot that could change
So, if anyone has some constructive criticism to give, or just general feedback I am happy to hear from you guys!
The facts:
Dimensions (not final):
Standalone (11.9 litre)​
180mm fan attachment (13.03 litre)​
200mm fan attachment (14.6 litre)​
330mm x 190mm x 190mm​
368.5 mm x 190mm 190mm​
371.5mm x 210mm x 210mm​
Features (not final):
  • Completely tool less installation of every component​
  • Supports a full-sized ATX power supply​
  • Graphics Cards support up to 275mm​
  • CPU cooler support up to 37mm​
  • Supports up to 2 x 2.5 inch SSDs​
  • Supports up to 1 x 3.5 inch HDD​
  • Basically zero cable management needed​
Impressions
Case with 200mm fan attachment (front)
Case with 200mm fan attachment (back)
Insides of the case
Reactions: Dazr87
Revenant
Revenant Tech
1,674
2,708
I like the idea. It's a neat concept. A couple of questions though:
Why ATX? It seems that if low mount an SFX you can rotate the mainboard and have a much large CPU cooler.
Are those perforations the final design? They don't seem large enough to allow much airflow.
Reactions: rcodi
thizzky
Design of the case is pretty nice. Interesting choice to support ATX psu as most SFX can support high-end components - why not prioritize larger cooler options instead?
Reactions: rcodi
tinyitx
2,279
2,338
I totally agree with the above posters. To me, ATX PSU support is not needed at all. I much prefer to have SFX (not even SFX-L) support and give extra space to a taller CPU cooler. 37mm CPU clearance is a big turnoff for me. Also, GPU length of 275mm, hopefully, can be longer.
So, this is basically a bottom air intake + top exhaust case. I like this idea.
Reactions: thizzky
chyll2
431
362
following this case. To OP, just stay true to your vision while still taking potential ideas/feedbacks. Personally, I really like the renders so far and the design concept but like most have said, I also consider ATX pointless as a feature set for a SFFPC.
Reactions: Daniel.f2277
