Hello good people! I have created a rough prototype for a laser-cuttable micro-atx chassis of a very basic construction. This is intended as a familiarization with Inkscape and an entry into case design. While it may not be small-form-factor, it is slightly smaller than a ATX case. It is inspired by the Thermaltake Core cases.
However, I do not have access to a laser cutter nor acrylic, so it would be awesome if you people could do any of the following:
Thanks!
Link to SVG File
(hopefully the correct size)
You can contact my over PCPartPicker as well...
- Add suggestions about the design (if you could provide SVG files, that would be awesome)
- Cut it out of 0.125 in acrylic, build a computer inside of it, and test it for fit
- Contribute ideas about features you would like to see.
Thanks!
Link to SVG File
