Hello Folks
Posting my unRAID server that I've been using for Plex and some docker containers, Parts are from previous builds and some HDD/SSD I had laying around.
Hardest part of the build was getting the Noctua L12s to fit with 25mm fan and the shell closed, as you can see it's scratching abit but manged to close it by pushing the cooler a bit while closing.
To get around the limited SATA situation I found a Silverstone Micron JMB585 controller M.2 to SATA expansion card. currently plugged a SATA SSD which is set to cache in unRAID & one pool disk, the rest are connected to the MB. with the extra SATA ports this gives me a total of 11 drives capacity (including the the back m.2) though the max you can squeeze in this case is 8 maybe 9. (5X3.5" drives - 2X2.5" SATA SSD - 1XNVMe SSD)
As for fans, I replaced the stock front fan with Arctic P12 and the cooler with Noctua 25mm (you need VLP RAM to make it fit). Also double tapped a side fan to cool the SATA and NVMe SSD's and they seem to do well with some reads and write tests.
Part List
CPU: Ryzen 5 5600X
CPU Cooler: Noctua NH-L12S w/Noctua A12x25
Motherboard: Gigabyte X570SI
Memory: Micron MTA18ADF2G72AZ-3G2E1 32 GB (2 x 16 GB) DDR4-3200 CL22 ECC Memory
GPU: Quadro T1000
Case: Jonsbo N1
PSU: Corsair SF750
Case Fans: ARCTIC P12 & Noctua A9
Expansion Card: SilverStone ECS07
Storage: Samsung 980 Pro 500GB NVME
Samsung 860 Evo 500GB SATA SSD
WD Caviar Green 8 TB "Shucked"
WD Red 8 TB "Shucked"
WD Red 12 TB
Seagate IronWolf NAS 12 TB
Part List
CPU: Ryzen 5 5600X
GPU: Quadro T1000
Case: Jonsbo N1
PSU: Corsair SF750
WD Red 12 TB
