Log Josnbo N1 BUILDS problem
pelikann1992
Parts list
MOB:ASUS STRIX B550-I GAMING
CPU:AMD RYZEN 5 5600X
MEMORY: 2x32GB (64GB) Pamięć Kingston Fury Beast, DDR4, 32 GB, 3200MHz, CL16
CASE:JONSBO N1
COOLING fan: amd wraith stealth/NH-L9a-AM4
DISK SSD: 1TB 2.5
DISK HDD:1x4TB,1x8TB,1x12TB
I do not know if we assembled well because the problem about the temperature at the CPU something is not right at work because when assembling it immediately heats very high itself turns off and we are constantly puzzled whether to add water with liquid or what someone may know or draw where to have air or someone will tell you about cooling in which or where to connect
PLS HELP
eedev
154
286
Hello,
I have that case in my basement right now, unused; it was too loud and too hot.
Depending on the fact that you have put it:
- vertically, you can put the big fan to exhaust
- horizontally, you can put the big fan to intake
Also, you could uninstall the top metal plate (it's removable) to allow for more air to get in (and less noise from turbulences).
In the end, my 5 hard drives were so hot that it was worrying me and I decided to go back to my old Fractal Node 804 instead.
If it's a fresh buy and you can return it, it's what I would do.
