Inwin A1 - "Custom" Build
peteC
Mar 28, 2019
Hi guys I just want to ask. Does this case have the normal I/O connectors that you need to connect to the motherboard?
I cant find the normal power switch cables that needs to go to the motherboard.
2,201
2,215
This is what the manual says about the front panel connector, at least:
Looks like a standard setup to me (though easily mistaken for the HD Audio connector shown below if you're used to every connector being separate).
GerryMz
56
Welp, it's done! I'm not sure what was wrong with it but I disassembled, reassembled and magically everything worked. Everything fits, although I think I need to redo the cable management in the back as the side panel over there fits very snugly. I have a few plans in the future, such as replacing the PSU with an SFX one, custom-length cables, and then seeing if I can swing a small monitor in there for temps and things. We'll see.
[/CENTER}​
Hey awesome build ! i was thinking of getting this cooler, which model is this exactly? & what are your temps like on the cpu while gaming or stress testing? thanks in advance !
Reactions: masbroo69
