Since I wasn't able to find the perfect case that would fill all requirements I had, I decided to sketch a layout for the case which has small area footprint that is mostly quadratic (depth and width are similar), does not have vents at the front, top or on the sides of the case, supports full-length GPU and has volume under 17 liters.
Here is the layout I came up with:
VIEWPOINT FROM THE LEFT SIDE
VIEWPOINT FROM THE BOTTOM
FRONT LEFT VIEWPOINT
This layout supports:
The inner volume of the case is 14.5 liters.
The first potential problem I see is the ATX PSU. There is barely any space for cable management so a SFX PSU might be a better fit. Using a SFX PSU would allow me to reduce height by approx 15 mm, although that would mean reducing GPU length by approx 15 mm as well.
Can some experienced designers like @Necere, @PlayfulPhoenix, @dondan, @Josh | NFC, @K888D, @sergiiua, @ZombiPL, @AlexTzone, @macbosco, @Lone, @Matt3D, @CircleTect, @grsychckn, @firewolfy, @LukeD, @DSE chime in and tell me what other potential problems this layout has.
- full-length GPU,
- Mini-ITX motherboard,
- ATX PSU,
- tower CPU cooler,
- three 120 mm fans (one at the bottom as intake fan, two at the back of the case as exhaust fans).
