Advice I am planning a gaming build, need some advice and suggestion.
894
Hi everyone this is going to be my first build in like 5 years, and first try in SFF. Moving from a laptop.
My aim is 95% of the main title in 3 year from now will be able to run on this platform with top quality no under 144hz in 1440p.
The case need to be sub 10L, I am live in a rental flat, may need to move a lot.
No custom loop (I am not ready yet).
CPU Zen 3 5900x
CPU Cooler AIR APX-90 Cu
or
CPU Cooler Water CORSAIR H100i (or should I pick something else can fit in Form T1 with better performance? here is a reference from Optimum Tech)
Graphics card 3080 Tuf
Case Formd T1
MOBO ROG B550I
Memory CORSAIR 3600 32g (I am not sure which model yet, but I am not into RGB, and I am not using a glass case, so whatever)
PSU CORSAIR SF750
SSD HOF PCIE4.0 m2 1TB
The shopping season will be on next month. do you have any advice or suggestion on this pre build? Thanks.
Reactions: Mafiaskafia
Mafiaskafia
My configuration is almost the same as yours, looking to see what other recommend. Also would like to know temps for the TUF in the T1.
