Log Planning new SFF Build in the Formd T1
sc2687
I am downsizing my previous ATX build to the Formd T1. I have most of the components with me and need some advice on the remaining parts. Here are my parts so far;
Case
Formd T1
CPU
AMD Ryzen 9 5900X 12 Cores - 3700 MHz - 105 watts
GPU
Colorful iGame GeForce RTX 3080 Advanced OC D6X 10GB
PSU
Corsair SF 750 W 80+ Platinum Certified Fully-Modular SFX Power Supply
AIO
Cooler Master MasterLiquid LC240E RGB Close-Loop AIO CPU Liquid Cooler, 240mm Radiator
I am planning to water cool my CPU with a dual radiator and keep the GPU air-cooled. Any advice on the motherboard, RAM and the memory storage!
Also, any other comments are appreciated. This is my first itx build!
tinyitx
2,112
2,082
That card is 60mm thick in the spec. Supposedly, Colorful counts this thickness from outer surface of backplate to the tip of the fans (ie max stock thickness). T1 has (3-slot mode) 59.2mm allowance (counting from back of card pcb to side panel).
If we assume the thickness of the backplate plus the gap is about 3mm, then this leaves about 2mm clearance between fans and the T1 side panel. Physically it should be compatible. But acoustically, this might be too narrow and causes turbulence noise. Just beware.
