The parts have started arriving!
The Sliger case has just flown in from the USA and is arriving today.
Asus Strix B550 i ITX
(run one in another computer, no issues, stick to what you know I suppose?)
AMD 5600X
(plenty for lounge PC/gaming)
Corsair SF750
(runs without fan in my 3950X and 1070GTX Streacom DA2 case, so perfect for a very quiet HTPC with a similar total power load expected)
1TB 980 Pro SSD
(have a server to store media and all that stuff, so 1TB should be plenty for OS install and games etc)
Corsair 16GB (2x8GB) 3600Mhz RAM
(plenty for gaming or HTPC use)
Alpenfohn Black Rock
(with Noctua back-plate, leaves room for 27mm of fan on top, might try push that to 30mm with spacers on the lid!)
Next steps are to measure up the exact space/clearance for the CPU cooler fan (might try squeeze a Phanteks T30 in, or stick to a Noctua AF12x25) and the GPU/fans space available.
I'm fairly sure I want to run a 3070FE GPU due to the fans config and efficiency. It'll hit 4k at 60hz fine for a big OLED TV on most games, but can undervolt to about 180W and run pretty quietly.
Also going to figure out how much space there is behind the GPU for fans/air management too, and space generally for ducting. Intend to quite heavily manage airflow intake, internal flow, and exhaust.
I've seen quite a few builds throwing loads of watts into one of these, but not much done at a more moderate level and a focus on making it very quiet, so I'll really try keep a lot of details/benchmark information for people to follow.
AMD 5600X
Corsair SF750
1TB 980 Pro SSD
