Hi everyone,
I have a HP ProDesk 400 G4 Microtower PC with a intel i5-7500 processor, 8 GB of RAM, Intel HD Graphics 630 and running OEM Windows 10 Pro - 1709, build 16299.64
Recently I decided do to a monitor upgrade and bought a 27 inch 4K monitor - LG 27UD58
However, that is when the things went south. Now it seems the computer hangs all the time, the refresh rate is set correctly to 60 Hz @ 3840x2160 , DPI 150% (recommended).
The computer hangs terribly, RAM usage is so high (varies between 80-100%) when using Chrome with multiple tabs.
So I decided to buy a dedicated graphics card, maybe this is the reason why the computer is so slow.
Before this, I was using a similar 27inch monitor but only full hd 1920x1080. Everything was smooth.
The connection between the monitor and desktop is via Display Port cable.
Latest drivers for everything are installed.
I was thinking to go for this one Gigabyte GeForce® GTX 1050 Ti OC Low Profile 4G
Any thoughts ?
Any thoughts ?
