I just build my computer 3 months ago, and now it showed a serious problem: high fever on SSD
When I was playing and streaming 3 days ago, the computer frozen for a few seconds then turn to a GSOD,
CRITICAL_PROCESS_DIED or something else, as same as you pull out your SSD when it is running.
After reboot, the computer boot into the UEFI setting, which indicate SSD is not found.
Then I went bed and had a sleep, on the next morning the SSD was back and works as normal.
After a day of learning, I start streaming again, and this time the same thing happened.
My friend told me it is better to check the SSD temperature, so I downloaded AIDA64 and stressed the whole system
After 15 mins of stressing, the SSD had a temperature of 85 degrees Celcius, CPU has 80.
30 seconds later, the computer started frozen, and the latest figure of SSD temperature I saw is 88.
88, and I do believe this poor SSD already reached 90, which is only 10 degrees lower than the boiling point of water.
I'm using a Silverstone Raven RVZ02 case, Asrock AB350 ITX/ac and AMD Ryzen 5 1600 as CPU with a Noctua NH-L9a cooler.
You may think the cooler may be the core of the problem, but I think the core of the problem is the motherboard,
that SSD is installed almost in the back of CPU.
Now the countermeasure which I'm going to use is to bind a heatsink on the SSD. is that gonna work?
