As I suspected, it gets pretty hot when installed between two video cards.
Hardware Setup:
Intel 750 400GB AIC
i7 5930K
Gigabyte X99M Gaming 5
4x8GB Crucial 2400
2xGTX 980 reference
Noctua NF-P12
Windows 8.1 Pro running off 840 EVO
Here it is installed between the two reference GTX 980s. Side panel was installed when running the tests though.
Tests were done with the 750 as a secondary drive using the Intel NVMe drivers. For stress testing the 750 I'm using Iometer w/ 4 workers @ QD32 running 4K aligned random writes to the entire drive (pretty much worst case scenario). For the GPUs I used Unigine Valley with the Ultra settings (except fullscreen).
The Intel SSD Toolbox 3.3 (which is what the reviewers used) doesn't seem to be available yet so I used the
Intel SSD Data Center Tool to get the drive temps.
Assuming the ISDCT is installed to the default location (C: \isdct\) the following command (need to run from elevated prompt) will write the temp stats to a CSV file on the root of the drive:
Code:
C:\isdct\isdct.exe dump -destination c:\temp.csv -intelssd 0 datatype=nvmelog logid=197
Note: If you have more than one Intel Data Center drive (750, P3700, etc.) installed you'll need to figure out the drive's index number (the zero in the above command) with the following command:
Code:
C:\isdct\isdct.exe show -intelssd
Tests:
Iometer was left running for the entire testing period. Ran 3 tests, first no front fan, then front fan on, then front fan on and GPUs running Valley
1hour of Iometer, GPUs idling, front fan turned off
ambient: 24-25°C
750 temp: 53°C
1 hour of Iometer, GPUs idling, front fan @ 1020RPM
ambient: 26-27°C
750 temp: 49°C
1 hour of Iometer, GPUs running Valley, front fan @ 1020RPM
ambient: 28-29°C
750 temp: 72°C
Drive gets pretty toasty
Then with Valley still running I stopped the Iometer testing and ran ATTO:
So even with the video cards cooking the drive it doesn't seem to effect performance.
However, having the AIC version of this drive installed between two video cards will need to be carefully considered. The Intel spec rates the AIC version only up to 55°C operating temperature (2.5" version is rated up to 70°C). With really good case cooling and more typical workloads it should be OK depending on the video cards used.
Edit: Here's the AS SSD bench with the 750 as the primary drive:
